To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP Officejet Pro 8610 e-All-in-One Printer
After replacing an HP instant ink cartridge and printing 1 file, I got a message saying there was a problem with the printer or ink system.  I turned the printer off, unplugged it, and turned it back on, and got the same message.  I did a system diagnosis on the HP Smart app, and it said no issues were found, but the printer failure message remains.  Is there anything else I can try, or am I just out of luck and need to buy a new printer?
1 REPLY 1
Hi @FLYR47,
It sounds like your printer is experiencing an ink system issue even after replacing the cartridge. Here are some steps you can try to troubleshoot and resolve this problem:
1. Check the Cartridges
  • Reinstall Cartridges: Remove the cartridges and reinstall them, ensuring they are properly seated.
  • Clean Contacts: Use a lint-free cloth slightly moistened with distilled water to gently clean the electrical contacts on the cartridges and inside the printer.
  • Check for Damage: Inspect the cartridges for any damage or leaks.
2. Perform a Hard Reset
  • Turn off the printer and unplug it from the power source.
  • Wait for about 60 seconds.
  • Plug the printer back in and turn it on.
3. Reset the Ink System
  • Remove Cartridges: Take out all the ink cartridges from the printer.
  • Power Cycle: With the cartridges removed, turn off the printer and unplug it from the power source. Wait for a few minutes before plugging it back in and turning it on.
  • Reinstall Cartridges: Reinstall the ink cartridges one by one, ensuring each is properly seated before moving on to the next.
4. Update Printer Firmware
  • Ensure your printer's firmware is up to date. You can usually update the firmware through the printer’s settings menu or the HP Smart app.
5. Run Printhead Cleaning
  • Use the printer's maintenance menu to run a printhead cleaning cycle. This can often resolve issues related to ink flow.
6. Check for Blockages
  • Inspect Ink Vents: Ensure that the ink cartridge vents are not blocked. If they are, use a pin to gently clear the blockage.
  • Check Printhead: If your printer has a removable printhead, remove it and clean it thoroughly with a lint-free cloth and distilled water.
7. Use HP Diagnostic Tools
  • HP Print and Scan Doctor: Download and run the HP Print and Scan Doctor tool from the HP website. This tool can diagnose and fix many common printing problems.
I hope this helps.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Rachel571
HP Support
Sneha_01- HP support
