Windows 11 Support Center. -
- HP Community
- Printers
- Re: Once again: Print doesn't work, "waiting for printer to ...
11-14-2020 09:47 AM
Crazy! My situation is almost identical. This time it is also with HP Easy Start. Printing and scanning were fine before I did the HP upgrade yesterday. Now, only scanning works. What's up, HP? Can I somehow return to the former driver?
Solved! Go to Solution.
11-15-2020 02:59 AM
Hi @Dinodozer,
I'd like to help!
Try updating mac and printer firmware
To update the printer's firmware, refer - HP Printers - Updating or Upgrading Printer Firmware
To update Mac, try these steps - How to update the software on your Mac
Uninstall the printer software -
1. Click Finder in the Dock.
2. In the menu bar, click Go, click Applications, and then open the HP or Hewlett Packard folder.
a) If HP Uninstaller is in the folder, double click it, and then follow the on-screen instructions to uninstall the software.
b) If HP Uninstaller is not in the folder, continue to the next step.
3. Click and drag the HP or Hewlett Packard folder to the Trash icon in the Dock.
4. In the menu bar, click Go, click Go to Folder, type /Library/Printers, then click Go.
The Printers folder opens.
5. Click and drag the HP or Hewlett Packard folder to the Trash icon in the Dock.
6. Restart the Mac.
7. Right-click or Ctrl + click the Trash icon, and then select Empty Trash.
Install the printer software Software and drivers for HP Deskjet Ink Advantage 1515 All-in-One Printer
You can also install the HP Smart App and print and scan using the app.
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
11-14-2020 12:35 PM
I hope this helps someone down the road. I decided that this issue was an HP software bug. I saw an article
A [software component] will damage your computer message displays when printing or while installing - Click Here."
It was not the error message I received; however, it pointed to the issue being HP software. That article points to an uninstaller for HP software. I uninstalled the HP software and then loaded the printer driver from Apple. Printed a testpage successfully! I'd like to upgrade to Big Sur. Is there an HP1515 driver that will work available yet? Thanks
11-15-2020 02:59 AM
Hi @Dinodozer,
I'd like to help!
6. Restart the Mac.
11-17-2020 12:55 PM
I did a couple of things today. 1) Purchased an HP 2775 at a local business. 2) Came home and installed Big Sur on my laptop. 3) Tested printing on HP1515 without changing a thing. Pages printed successfully!
11-19-2020 07:01 AM
That's great! Happy to hear that.
If you need further assistance feel free to reach out to us.
Have a great day ahead!
Please click “Accepted Solution” on my public post if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
