To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
On my HP Smart Tank 7602 printer I have ink lights flashing. On top panel I have a display box with variegated lines and the number B30C213B under the box. The red X is blinking, the white back button is flashing and the white help button is flashing. I cannot turn printer off. No button will respond. There is no paper jam. The front light under the HP logo looks ivory and does not blink.
Do you what error box message means?
1 REPLY 1
@4sure2day
Welcome to the HP support community.
I understand that you are getting an error on the printer, I am glad to assist you.
Perform a power reset , Reset the printer to recover from printer errors or failures.
  1. Turn on the printer, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Wait at least 30 seconds.
  5. Plug back the power cable straight to a wall outlet and printer without any surge protector.
  6. Turn on the printer.
Update the printer firmware to install the latest updates
Here are the steps:- Click here
Refer to this HP document for more assistance:- Click here
Keep me posted.
If this helps, please mark the public post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
