Windows 11 Support Center. -
- HP Community
- Printers
- an Re: Supply Problem Error - Help!
11-14-2020 01:08 PM
My printer started an auto update of firmware. Partially through, the update appeared to stop and now receiving "Supply problem" error message with "question marks" on all 4 cartridges. The cartridges were a few months old and have had no problem printing until the firmware update. I have since replaced all cartridges with the same issue. Has anyone seen this and can you suggest how to fix?
11-15-2020 11:17 AM
Hello,
Kindly check your INBOX ( click the ENVELOPE icon on top right of this page ) for steps that should fix the issue.
Let me know if the steps worked for you.
Jabzi
Give Kudos to say "thanks" by clicking on the "thumps Up icon" .
Click "Accept as Solution" if it solved your problem, so others can find it.
Although I am an HP employee, I am speaking for myself and not for HP.
11-15-2020 12:24 PM
Hello,
Kindly check your INBOX [ click on the ENVELOPE icon on top-right corner of this page ] to access steps that should fix.
Let me know if it worked for you.
Jabzi
11-15-2020 01:15 PM
Hello Kristimay,
I'd suggest to disable IPv6 and DHCP6.
In order to disable IPv6 on the Printer, use a web browser to navigate to the IP Address of the Printer. Once there, click on the networking tab, choose Networking Settings. There you will see a checkbox that says "IPv6". Uncheck that box, similarly uncheck the DHCP6 and click apply.
Now connect printer on network ana check if error still persist.
Jabzi
11-15-2020 02:10 PM
Turn off the printer.
Wait for 30 seconds
Now power on the printer.
It should work
Jabzi
