Windows 11 Support Center. -
- HP Community
- Printers
- Re: Supply System Problem
11-24-2019 06:00 AM
I just purchased this printer from PC World Ebay store and I'm beginning to think I've bought a dud. I have a" Supply System Problem" message that appeared with the set up cartridges and won't clear. I've tried all the solutions presented on here but to no avail. I've factory reset via EWS and enabled web services on there too. Changed cartridges and the Firmware is up to date and now I'm stuck! is there anything else I can try other than sending it back. As you can see it has been used and I'm wondering if it's an ex shop display model. Any help/suggestions would be gratefully appreciated.
Solved! Go to Solution.
11-27-2019 05:00 AM
Hi @Alsidy61
Appreciate you trying the steps. This looks like a hardware issue, I'd suggest you Contact HP in your region regarding the service options for your printer.
Have a great day!
Asmita
I am an HP Employee
11-27-2019 05:00 AM
Hi @Alsidy61
Have a great day!
Asmita
I am an HP Employee
