Windows 11 Support Center. -
- HP Community
- Printers
- Supply System Problem
02-04-2024 03:10 PM
Recently bought a HP 952 all 3 color pack due to my Magenta saying Supply System Problem. Went to install new cartridge and the same error is coming up. Updates are all caught up, turned it off and back on, cleaned each cartridge, cleaned the ink chamber out as well...still saying the same thing. Need help to fix this due to this is a business printer. TIA
02-06-2024 12:59 PM
Hi @DLouviee18,
I see that you are facing an issue with your printer that has a print system error.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, refer to the steps on this link to further troubleshoot.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
