Windows 11 Support Center. -
- HP Community
- Printers
- Supply system problem error
07-21-2025 02:16 PM
Hi @JAM60555
Welcome to the HP Support Community! We're here to help you get back up and running.
If you experience a "Supply System Problem" error after installing a new black cartridge in your HP OfficeJet Pro 8710, follow these troubleshooting steps:
Step 1: Check the Cartridge
Open the Cartridge Access Door: Slip your fingers into the slot on the left side of the printer and pull forward to open the door.
- Wait for the Carriage to Idle: The carriage will move to the left; wait until it is idle and silent.
Remove and Inspect the Cartridge:
- Push in on the front of the cartridge to release it, then pull it out from its slot.
- Check for Glue Residue: Ensure there is no glue residue blocking the ink supply hole.
- If glue residue is present, it can obstruct ink flow. Remove any residue before proceeding.
Reinsert the Cartridge:
- Carefully replace the cartridge in its slot and push forward until it clicks into place.
- Close the cartridge access door and try printing again.
Step 2: Replace the Cartridge If Necessary
If the error persists despite following the steps above:
- Contact HP Support:
- You may need to replace the cartridge under warranty. Visit HP Customer Support to check warranty status and request cartridge replacement.
- For any further errors or issues, updating your printer's firmware could help. For firmware updates, refer to Updating or Upgrading Printer Firmware.
Step 3: Replace the Printhead If Recommended
If HP Support indicates a printhead replacement is necessary:
Order a New Printhead: Visit the HP Parts Store to order a new printhead assembly, if it's no longer under warranty.
- Follow the on-screen instructions to identify the correct part number for your printer.
Follow Printhead Replacement Procedures:
- Detailed instructions for replacing the printhead can be found here.
These steps should typically resolve the "Supply System Problem" error
If my response helped, please mark it as an Accepted Solution! ✅ It helps others and spreads support. 💙 Also, tapping "Yes" on "Was this reply helpful?" makes a big difference! Thanks! 😊
Take care, and have an amazing day!
Regards,
Hawks_Eye
