Windows 11 Support Center. -
- HP Community
- Printers
- Thin lines, and small items made of thin lines not printing ...
10-02-2018 02:37 PM
Suddenyl my printer won't print fine lines in an image on a MS word page. It used to, now it won't.
Changed cartridges, updated foirmware, updated / re-installed software / drivers.
How it should look
This is how it now prints...
How it now prints and misses fine lines
10-02-2018 03:04 PM
Pleasecselect option fine or high quality not draft or economy from printer prpoperties and try again.
Regards.
10-03-2018 05:28 AM
Hi Banhien
I've tried all the easy one's.
The only way to get the lines is to enter the printer settings>Paper/Quality>Advanced>Prin in Max DPI>Yes and only on this setting do the thin lines come out.
It used to print them without all the special tweaking.
Issues with this are that it wastes far too much ink and takes 5 minutes per page even for a simple schematic as shown above.
Something has changed - and I changed nothing.
