Hi Will, just sent you a private msg....
I am speaking for myself and not for HP. Twitter: @Ciara_B_27
Hi, I have just encountered exactly the same problem. Brought printer second hand but have been using it with no problem until today. When I tried to print I had the same message to use Setup Cartridges. Printer won't shut down either. Just freezes on the menu and power button flashes. Any help would be gratefully received.
Hi Jane,
Some of the HP people are on holiday today.
I have sent a message asking for help.
Hang in there.
Happy 2014 !
Click the Kudos Star!
It is a nice way to say “Thank You” for the help.
Although I strive to reflect HP's best practices, I do not work for HP.
Dragon-Fur
Hi,
I have the same error on my printer , can you help me with a solution? Thank you
Hi @rainbow22
I'm going to private message you.
Ciara
Hi,
I have the same problem like above (deskjet 3070A , product CQ191B , model B611a).
Can someone help me ?
Thanks in advanced
Hi,
Same problem, "Use Setup Cartridges" after a printer restart. 3070A, B611 e-all-in-One, Regulatory Model NumberVCVRA-1111
Thanks for helping
I have done a semi-full reset twice , with succes.
How to do ?
Put the printer ON
Press button combination : back - cancel - back - back
The printer will show "Support menu" , press OK.
Scroll down until you find "Resets Menu" , press OK
Scroll down until you find "Semi-full reset" , press OK
You need to follow this process twice, after then the printer works again.
You have only to re-install the wireless and eprint function.
Succes
(I used original parts for this :smileyhappy:)
Johando,
Thanks for posting what worked for your printer - good to hear it is again working as it should.
Dragon-Fur
Hey !
I performed two semi full resets but it goes on the same way : needs setup tanks !
