To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP OfficeJet Pro 7740
Just purchased this HP OfficeJet Pro 7740 and have followed all the instructions.  Why can't I get the control panel to light?  It comes on then off.  So baffled.
1 REPLY 1
Hi @Carolyn_B
Welcome to the HP Support Community. I'd be happy to assist you.
Make sure the protective plastic tape if any is removed from the printer display screen before use.
Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Wait at least 60 seconds.
  3. Reconnect the power cord to the rear of the printer.
  4. Turn ON the printer, if it does not automatically turn on.
  5. Wait until the printer is idle and silent before you proceed.
Note: HP recommends connecting the printer directly to a wall outlet rather than a surge protector or a power strip.
Check if the icons beside the home screen are working.
Have a great day!
KUMAR0307
I am an HP Employee
