Windows 11 Support Center. -
- HP Community
- Printers
- Wifi and mobile connection issues
02-17-2023 02:52 AM
Hello, I have recently purchased a officejet 200 mobile printer, I have set the printer up and everything works except the wifi and mobile aspects of the printer, whenever I press that button it comes up with ‘this feature has been disabled. Contact the person who set up the printer’
02-21-2023 12:44 AM
Hi @Simonetaylor,
Wi-Fi Direct lets you print wirelessly from a computer or a wireless-capable mobile device without connecting
to a wireless network.
NOTE: When using the HP printer software to connect your printer to a computer, choosing the wireless
connection stores the Wi-Fi Direct profile of the printer into the computer after the connection successes. The
Wi-Fi Direct name is added into the wireless network list on the computer.
Guidelines for using Wi-Fi Direct
● Make sure your computer or mobile device has the necessary software.
– If you are using a computer, make sure you have installed the HP printer software.
If you have not installed the HP printer software on the computer, connect to Wi-Fi Direct first and
then install the printer software.
– If you are using a mobile device, make sure you have installed a compatible printing app. For more
information about mobile printing, visit the HP Mobile Printing website at www.hp.com/go/
mobileprinting . If a local version of this website is not available in your country/region or
language, you might be directed to the HP Mobile Printing site in another country/region or
language.
● Make sure Wi-Fi Direct for your printer is turned on.
● Up to five computers and mobile devices can use the same Wi-Fi Direct connection.
● Wi-Fi Direct can be used while the printer is also connected either to a computer using a USB cable or to
a network using a wireless connection.
● Wi-Fi Direct cannot connect a computer, mobile device, or printer to the Internet.
To print from a wireless-capable mobile device that does not support Wi-Fi Direct
Make sure you have installed a compatible printing app on your mobile device. For more information, visit the
HP Mobile Printing website at www.hp.com/go/mobileprinting . If a local version of this website is not
available in your country/region or language, you might be directed to the HP Mobile Printing site in another
country/region or language.
1. Make sure you have turned on Wi-Fi Direct on the printer.
2. Turn on the Wi-Fi connection on your mobile device. For more information, see the documentation
provided with the mobile device.
NOTE: If your mobile device does not support Wi-Fi, you are not able to use Wi-Fi Direct.
3. From the mobile device, connect to a new network. Use the process you normally use to connect to a
new wireless network or hotspot. Choose the Wi-Fi Direct name from the list of wireless networks
shown such as DIRECT-**-HP 2ffiFH-Ht XXXX (where ** are the unique characters to identify your printer
and XXXX is the printer model located on the printer).
Enter the Wi-Fi Direct password when prompted.
4. Print your document. For more information about print, see Print.
I hope this helps.
^ Alden4
HP Support
HP Support Community Moderator
