HP Photosmart premium 309C
I just put in all new ink and now the black is not working. I always use hp ink. I have tried cleaning the printhead both on the computer and by taking it out. I am now getting a failed alignment message.
1 REPLY 1
@vanett
If you in your old ink, are you able to print in black, though the print quality might not be great?
Also, are you able to copy in black with this new ink?
Let's try to reset the Printer here as it helps in removing any stored static electricity from the Printer which might be causing these issues.
  1. Turn the printer on, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
  7. NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
  8. Reconnect the power cord to the rear of the printer.
  9. Turn on the printer, if it does not automatically turn on.
  10. Wait until the printer is idle and silent before you proceed.
Also, try connecting the Printer to a different wall outlet directly.
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thanks!
Have a great day!
I am an HP Employee
