Windows 11 Support Center. -
- HP Community
- Printers
- Will not print on HP Advanced Photo Paper 5X7
05-15-2017 04:58 PM
Thank you so much! Installing the basic drivers worked! I have my 5X7 picture printed out right here and it's perfect! I truly appreciate it and I hope that others who must be having this same problem will find their way here.
So I shouldn't install any updated software for this printer, is that correct? The newer drivers were the issue?
Thank you so much again for sticking with the problem until it was fixed!
Lesa
05-16-2017 02:54 PM
Hello, @LIRN
Thanks for the update & Great stuff! Glad to know that you were able to fix the issue 🙂
You can perform any printer update which comes on its way. The driver package which we installed is the updated package. The basic driver only means that it does not include some components like HP help, HP shopping etc. But the printing and scanning driver is the same.
Visit us again if you have any concerns!
Thank you again and may you also have a great day and even better tomorrow 🙂
DVortex
I am not an HP Employee
08-02-2019 12:42 PM
I have been having the same problem as the original poster. I have followed all the instructions through the hard reset and just like them, I have not had any luck fixing the issue. I see that a special download of drivers solved the poster's problem, but I am using a mac (10.13.6) and the driver link is for windows systems. How can I get mac drivers that fix this issue?
08-02-2019 02:57 PM
Hello,
Thank you for posting in this thread. Unfortunately based on when the last response was made, I have closed this thread to help keep comments current and up to date. We recommend starting a new thread for your issue by clicking here.
To be more helpful with your post, you can add key information if you desire:
1. Product Name and Number (please do not post Serial Number)
• Example: HP Pavilion DV2-1209AX or HP Deskjet 3000 Printer CH393A
2. Operating System installed (if applicable)
• Example: Windows XP, Windows Vista 32-bit, Windows 7 64-bit
3. Error message (if any)
• Example: ""Low disk space"" error in Windows
4. Any changes made to your system before the issue occurred
• Examples: Upgrading your Operating System or installing a new software; or installing new hardware like a printer, modem, or router.
If you have any other questions about posting in the community, please feel free to send me a private message!
Thank you
I work on behalf of HP
- « Previous
- 1
- 2
- Next »
