Windows 11 Support Center. -
- HP Community
- Printers
- Won't clear jam and won't print.
04-20-2024 09:18 AM
Have MAC 14.4.1 computer - cannot print as flashing red ! indicates jam. Have removed cartridge and cannot find any paper jam. Have unplugged and restarted printer but problem remains. Any suggestions or help?
04-22-2024 06:46 AM
Hi @Cinders4,
It sounds like you've already done some troubleshooting steps, which is great. Here are a few more things to try for your HP LaserJet M110we printer showing a jam error.
Check all areas for jammed paper: Even small shreds of paper can cause the jam error. Make sure to check:
- Paper input tray.
- Toner cartridge area.
- Rear access door.
- Output tray.
Clear any visible paper: If you do find any paper stuck, carefully remove it. Be gentle to avoid tearing the paper.
Reset the printer: Turn off the printer, unplug it from the power source, and leave it unplugged for a few minutes. Then plug it back in and turn it on. This can sometimes reset the printer's internal sensors.
Check for foreign objects: Sometimes objects like paper clips or debris can get into the printer and cause jams. Look carefully inside the printer for any such objects and remove them.
Inspect the rollers: Printer rollers can accumulate dust and debris over time, leading to jams. Gently clean the rollers with a lint-free cloth dampened with water. Avoid using alcohol or other harsh chemicals.
Update printer firmware: If none of the above steps work, it might be a good idea to update the printer's firmware. HP often releases firmware updates to address issues like these. You can usually find firmware updates on the HP support website.
I hope this helps.
Alden4
HP Support
HP Support Community Moderator
