HP DeskJet 2332 All-in-One Printer
macOS 10.14 Mojave
i have a 2332 deskjet and using on mac, whenever i try to print the power button just starts flashing, its telling me on support page to make sure the ink door is closed but it isnt open, i have opened and closed it to try  see if that did anything but no luck. i need help here...
1 REPLY 1
Hi @zeannawhit,
Welcome to the HP Support Community
I'd like to help!
I understand  the pirnter power button flashes.
This condition occurs when the ink cartridge access door is open. The following control panel light pattern displays:
Resume light: Off
Power light: Blinking fast
Ink Alert light (black): Off
Ink Alert light (tri-color): Off
Power light
Make sure to close the ink cartridge access door completely.
Figure : Close the ink cartridge access door
Image: Close the ink cartridge access door.
Also,refer to -https://support.hp.com/us-en/product/hp-deskjet-2130-all-in-one-printer-series/7174550/document/c04...
Click the “Yes" on the bottom right to say “Thanks” for helping
