officejet pro 7730
Hi - just bought a new officejet pro 7730. for some reason the print qulaity on A3 is a lot lower than on a4 paper?
2 REPLIES 2
@willmcg
The following is general information based on the subject and not specifically related what your printer can (or will) do.
Lower quality at larger size can be linked to the pixel count (PPI = Pixels per Inch / density) of the image.
A3297 x 420 mm11.7 x 16.5 in
A4210 x 297 mm8.3 x 11.7 in
DPI / Print Resolution and size affects the outcome.
Understanding DPI and how it relates to printing
Clearly written and easy-to-understand, background on the mysteries of DPI:
Understanding DPI and Pixel Dimensions
There many articles of this type on the 'net.
Search for ppi and dpi explained
Reference and Resources – (More) Places to find help, solve problems, and learn how to use your Printer
Printer Homepage – “Things that are your printer”
NOTE:  Content depends on device type and Operating System
Categories:  Alerts, Access to the Print and Scan Doctor (Windows), Warranty Check, HP Drivers / Software / Firmware Updates, How-to Videos, Bulletins/Notices, Lots of How-to Documents, Troubleshooting, User Guides / Manuals, Product Information (Specifications), more
When the website support page opens, Select (as available) a Category > Topic > Subtopic
HP OfficeJet Pro 7730 Wide Format All-in-One Printer series
Thank you for participating in the HP Community Forum.
We are a world community of volunteers dedicated to supporting HP technology
Dragon-Fur
Thanks Dragon-Fur but when i print the document to A3 size but on A4 paper the print is perfect. my old hp scanner/ printer/ fax machine printed good quality on both a3 and a4. i swapped the trays/ changed printer settings but problem persists.
