Cartridge not calibrated for best print quality, HP5510 Photosmart. Have new black but very low on colors, skips some lines, printing monochrome. Tried realigning, cleaning printhead etc.
Hi there, if your problem is poor print quality then its most like ly the cause is the very low levels in your colour cartridges. Here's a link to a support document that takes you through some troubleshooting steps but you should probably have replacement cartridges on hand before you proceed as this is one of the first suggestions you'll be given.
http://support.hp.com/us-en/document/c02914910
Best.
I am an HP employee.
If my reply helped you, feel free to click on the Kudos button (hover over the "thumbs up").
If my reply solved your problem please click on the Accepted Solution button so other Forum users may benefit from viewing the post.
3 REPLIES 3
Best.
New cartridges and Ive attempted all 3 head cleaning solutions.  Colors are perfect but black will not print.  Err msg is "you may continue but Cartridges aren't calibrated for best print quality. "  Please help   JIM
I'm setting up my B209A Photosmart Printer with new cartridges.  I ran the scanner alignment test and have gotten:  "Cartidges are not calibrated for best print quality."  How can I fix this?
