HP DeskJet 4133e All-in-One Printer
I tried the fixes (unplug then turn back on after wait, several times, installed new cartridges, nothing worked. I have had the printer less than on year and it is always getting stuck. I regret buying it but would like to get it working since I did.
1 REPLY 1
Hi @Bacoe,
I'm sorry to hear that you're experiencing issues with your HP DeskJet 4133e printer. Here are some troubleshooting steps you can try to resolve the problems.
Power Cycle:
  • Unplug the power cord from the back of the printer.
  • Wait for about 30 seconds.
  • Plug the power cord back in.
  • Turn the printer on.
Update Firmware:
  • Check if there's a firmware update available for your printer on the HP support website.
  • If an update is available, follow the instructions provided to update the firmware.
Check for Paper Jams:
  • Make sure there is no paper jam in the printer. Even a small piece of paper can cause issues.
  • Open the printer cover and check all areas for any stuck paper.
Check Cartridges:
  • Ensure that the ink cartridges are properly installed and securely in place.
  • Make sure you've removed any protective tapes or seals from the cartridges.
Clean Cartridge Contacts:
  • Turn off the printer.
  • Remove the ink cartridges.
  • Clean the copper-colored contacts on the cartridges with a lint-free cloth.
  • Reinstall the cartridges.
Reset Printer Settings:
  • Go to the printer settings on the control panel and perform a factory reset.
  • Refer to the printer manual for instructions on how to reset the printer.
Check for Software Issues:
  • Ensure that the printer drivers are up-to-date. You can download the latest drivers from the HP website.
  • If you have recently updated your computer's operating system, make sure the printer is compatible.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
