@Ryan2 wrote:
hp2542 blue light flashing and will not connect
Please provide the following relevant information so someone can help including:
Printer Model -
Detailed Problem Description -
Operating System of computer (including service pack revision) -
Connection Method - USB, Hardwired LAN, Wireless? -
Make and model of router and modem? -
Error messages - on printer screen and/or computer, any blinking light patterns?
If wireless, when the problem occurs, what is status of Blue Wireless light on printer, on, off or blinking? –
Power off printer and router. Power on router and wait 3 mins, power on printer. Does it connect to the router now? Do you have a valid IP address?
hello, i have the same issue here. Deskjet 3050A.. blue light flash. trying WPS button. no luck. I have directly connected printer to my macbook and it works. I tried to use the original CD but it only works with os 10.6 and below... I cant find any other software on HP for my printer... please help.
Hi @vzbar,
Welcome to the HP Support Forums!
I see that your HP Deskjet 3050A e-All-in-One Printer is not connected to your wireless network. I would be happy to help you and please remember to return to this thread and mark 'Accept as Solution', if I have successfully helped you resolve the issue. If you wish to say 'thanks' for my effort to help, click the 'thumbs up' to give me a Kudos.
Please follow the steps within this guide to reconfigure the wireless:
I hope this information is helpful. Please respond to this post with the results. Good Luck!
Drakster
I work on behalf of HP
If you found this post helpful, you can let others know by clicking the Accept as Solution button. You can also show your appreciation, with a kudos, by clicking the thumbs up" button!
Can i connect my cell phone to the printer i dont have a computer
No sorry.  Must have a router also to connect wirelessly.
