Windows 11 Support Center. -
- HP Community
- Printers
- if I connect my laptop to my printer using wifi direct, will...
01-13-2019 01:12 PM
if I connect my laptop to my printer using wifi direct, will that disconnect it from internet?
Solved! Go to Solution.
06:55 PM
- last edited on
08-20-2024
06:57 AM
by
JessikaV
Welcome to the HP Forums!
Thank you for posting your query on this forum, it's a great place to find answers.
I reviewed your post and I understand that you want to know if you connect the laptop to the printer using Wi-Fi direct will it disconnect from the Internet.
Don’t worry, I assure you I will try my best to get this sorted.
I would like to inform you that the laptop will disconnect from the internet as it will connect to the wireless network created by the printer.
Please refer to the below article to set up Wi-Fi direct.
https://support.hp.com/us-en/document/ish_1841315-1637332-16
Hope that answers your question and you have a great day!
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
The_Fossette
I am an HP Employee
01-14-2019
06:55 PM
- last edited on
08-20-2024
06:57 AM
by
JessikaV
Cheers!
The_Fossette
I am an HP Employee
