HP LaserJet Pro MFP M126a
in my laserjet printer, "HP" Displays on the control panel and the attention light blinks. and the printer didn't able to connect with my lap, getting message while connecting "An error occurred communicationg with the printer." I tried everything, I update my lap, windows, off the antivirus, change the cable, replace the cartridge. but still I cant able to use my printer, even the photocopy didn't works, everything stucked, I am tried every possible works, please me with this...
3 REPLIES 3
Hi @Chetan57,
It sounds like your HP LaserJet Pro MFP M126 is experiencing a significant issue where the display blinks and shows "HP," the attention light blinks, and you can't communicate with the printer from your laptop. Given that you've already tried several troubleshooting steps, here are some more detailed steps to diagnose and potentially resolve the issue:
1. Power Cycle and Reset
Power Cycle the Printer:
  • Turn Off: Turn off the printer using the power button.
  • Unplug: Disconnect the power cord from the printer and wait for at least 60 seconds.
  • Plug In and Turn On: Reconnect the power cord and turn the printer back on.
Perform a Hard Reset:
  • Unplug Printer: Unplug the printer from the power source.
  • Hold Power Button: While unplugged, press and hold the power button for about 15 seconds.
  • Reconnect and Power On: Plug the printer back in and turn it on.
2. Check for Error Messages and Indicators
Review Error Messages:
  • Consult Manual: Check the printer’s manual or HP’s support website for error code meanings. The blinking "HP" and attention light often indicate specific issues.
  • Reset Printer: If the manual provides a reset procedure for error conditions, follow those instructions.
Check Lights:
  • Attention Light: If the attention light is blinking, it usually indicates an issue that needs attention, such as paper jams, low toner, or hardware faults.
3. Check for Paper Jams and Hardware Issues
Inspect for Paper Jams:
  • Open All Panels: Open all access panels and trays to check for any paper jams or obstructions.
  • Clear Jams: Remove any jammed paper carefully, following the instructions in the manual.
Inspect Hardware:
  • Check Toner Cartridges: Make sure the toner cartridges are properly installed and not damaged.
  • Check for Foreign Objects: Look inside the printer for any foreign objects or debris.
4. Update or Reinstall Printer Drivers
Uninstall Existing Drivers:
  • Open Device Manager: Press Win + X and select Device Manager.
  • Find Printer: Locate your printer under Printers or Unknown Devices.
  • Uninstall: Right-click the printer and select Uninstall device.
Download and Install Latest Drivers:
  • Visit HP’s Website: Go to HP’s support website and search for your printer model.
  • Download Drivers: Download and install the latest drivers for your operating system.
5. Check Connectivity
Verify USB Connection:
  • Change Cable: Try using a different USB cable to rule out a faulty cable.
  • Test Ports: Connect the printer to a different USB port on your laptop.
Test on Another Computer:
  • Check with Another Computer: Connect the printer to another computer to determine if the issue is with the printer or the original computer
I hope this helps.
Take care and have a good day.]
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Rachel571
HP Support
Sneha_01- HP support
hi Rachel,
Thankyou for your response, i tried everything you shared with me, but still i didnt get the solution, The Printer Still blink "HP" continuosly on display, and attention light al blinking.
when this Probelm was Start ?
My lap is Updated automatically when the update is comes, so last month when the new lap update was come, on that time my lap was connected with the printer, my lap goes to Update mode, and after the lap update, the printer faced this problem. from last month to till now i didnt able to use this printer, i am stucked, & im done with every possible way for solving this issue, please help me..
Hi @Chetan57,
Welcome to the HP Support Community
I'm sending a private message to assist you with the next action.
Please check your Private message icon on the upper right corner of your HP Community profile Next, to your profile Name, you should see a little blue envelope, please click on it or simply click on this link.
I hope this helps! Keep me posted.
Alden4
HP Support
Raj_05
HP Support Community Moderator
