my HP OfficeJet Pro 8600 will not print at all--it says "ink system failure" "problem with printer or ink system.  Have turned off and back on multiple times as instucted.
1 REPLY 1
@SiviB, Welcome to HP Support Community,
Thank you for posting your query; I’m here to help by guiding you through steps to resolve this issue
Restart the Printer
  1. Turn off the printer.
  2. Unplug the power cord from the back of the printer.
  3. Press and hold the power button for 30 seconds.
  4. Wait for 60 seconds and connect the power cord back in.
  5. Turn on the printer.
Run HP Print and Scan Doctor (Windows only):
Update Printer Firmware (Update the firmware on an HP printer | HP® Support)
  • Go to the HP Customer Support - Software and Driver Downloads page. Enter your printer model number and search for the latest firmware update. Follow the instructions to download and install the firmware update.
Also, refer to this guide: HP Printers - An 'Ink System Failure,' 'System Supply Problem' or 'Supply System Problem' Error Disp...
I hope this helps.
Please feel free to reply here if you have any questions or if you need further clarification on any of the steps.
If my response helped, please mark it as an Accepted Solution It helps others and spreads support. 💙 Also, tapping "Yes" on "Was this reply helpful?" makes a big difference! Thanks! 😊
Regards,
Garp_Senchau
I am an HP Employee
