My HP7720 prfinter is in idle mode how to fix
1 REPLY 1
@bpb788, Welcome to the HP Support Community – it’s great to have you here!
I appreciate you taking the time to share your question. I'm more than happy to assist with this and provide a solution that works for you.
If your HP OfficeJet Pro 7720 printer is showing “Idle” status, it usually means the printer is not actively printing and is waiting for a job. However, if you're unable to print or the printer seems stuck in idle, here are some steps to help resolve the issue:
Check Printer Connection
  • USB Connection: Ensure the cable is securely connected to both the printer and PC.
  • Wi-Fi Connection:
    • Make sure the printer is connected to the same Wi-Fi network as your PC.
    • You can check this on the printer’s control panel under Wireless Settings.
Restart Devices
  • Power off the printer and unplug it for 30 seconds.
  • Restart your computer.
  • Plug the printer back in and turn it on.
Set Printer as Default
  • Go to Settings > Bluetooth & devices > Printers & scanners.
  • Select your HP OfficeJet Pro 7720.
  • Click Set as default.
Clear Print Queue
  • Open Control Panel > Devices and Printers.
  • Right-click your printer > See what’s printing.
  • Cancel any stuck print jobs.
Reinstall Printer Driver
  • Uninstall the printer from Settings > Printers & scanners.
  • Download and install the latest driver using HP Easy Start: Official HP® Support
Check for Windows Updates
  • Go to Settings > Windows Update and install any pending updates.
Additional Tips
  • Ensure the printer is not in Sleep Mode. Tap the screen or press a button to wake it.
  • If using third-party software, try printing directly from a basic app like Notepad or Word to test.
I hope your issue is now resolved. If not, feel free to reply and we’ll continue helping until everything’s sorted!
If the post helped, please click “Accepted Solution” to help other users easily find it. And if you’d like to say thanks, just tap the “Yes” button!
Cheers,
Max3Aj
HP Support
