Windows 11 Support Center. -
- HP Community
- Printers
- Re: officejet pro 8210 - persistent print queue problem
04-14-2017 01:21 AM
Thanks for the detailed reply. Unfortunately changing the print processor did not work for me. I had 2 other processors available: hpzppwn7 and hpzppw71, but neither one of them made any difference when selected. I checked my Win 7 laptop (which does not have the issue with the 8210) and the print processor was set to winprint.
This is really irritating. If I could charge HP for the time I have wasted on this so far I could buy a new laptop and printer.
04-14-2017 12:47 PM
Sorry I haven't checked in for a while, I've been struggling with this issue since December and can only devote time when all other fires are put out.
I did just do the following and successfully printed out a 3 page document 5 times in a row:
Printer Properties, Advanced, Driver Dropdown box
In our case these Officejet 8210's were replacing Deskjet 6940's. On a whim I changed the driver to the old printer and it's worked every time.
Will keep an eye on this and report back, but so far so good.
04-25-2017 08:19 AM
An update to what I thought was a fix, it was only temporary. We started have items stuck in queue again.
@TJack123 wrote:I also had problems with stuck in queue after printing with a HP OfficeJet Pro 8710. I found this solution and it has worked so far - http://www.acarte.com/2017/03/23/second-print-job-fails-on-hp-printer/
Basically I went to Printer Properties -> Advanced tab -> Print Processor
Changed from "winprint" to "hpcpp6de". The article said to change to "hpzpplhn" but I did not have that choice. See what you have and try different "hp******" choices listed there to see if it will work for you.
04-26-2017 01:34 PM
Hi @TJack123,
Thanks for stopping by the HP community. Good Day.:) I reviewed the post regarding the printer’s print job getting stuck in queue. I will be delighted to assist you here. 🙂
Fabulous description, superb troubleshooting and brilliant effort to fix the issue before posting. Kudos to you for that. 🙂 You are a valued HP customer and it is paramount to assist you with it. I take it as a privilege to share this platform with you. 🙂
- Did you bypass power strips and perform a hard reset on the printer?
For starters please try all the prescribed steps mentioned in this link to try and get the issue fixed if it has not been done already. I am sure you've done it.
I thank you greatly for sharing this information on the HP forums by keeping the best interest of others in mind. It was magnanimous on your part to share this vital information. 🙂 It will assist several others to get the issue fixed.
Hope this helps. Let me know how this goes. I genuinely hope the issue gets resolved without hassles and the unit works great.
To simply say thanks, please click the "Thumbs Up" button to give me a Kudos to appreciate my efforts to help. If this helps, please mark this as “Accepted Solution” as it will help several others with the same issue to get it resolved without hassles.
You take care and have a fabulous new year ahead. 🙂
DavidSMP
I am an HP Employee
04-26-2017 02:01 PM
David, the posters in this thread have already displayed quite thoroughly that we are beyond power strips...please pass this on to someone that is willing to put in some effort to get this USB Driver issue resolved.
04-27-2017 07:11 AM
Rwallis99....
Thank you for your response!
Clearly "David" never read through the entire thread. Power strips, indeed! What an insult! Too many "kudos" offered and not enough substantive information! Pitiful "support" from HP.....
06-21-2017 01:45 PM
I had no problem with the printer until I got a new laptop with Windows 10. The problem was periodic but seemed to occur at least once each day. I went through the steps to delete the job, but the problem would still reoccur. I did find a solution in this forum - I changed the print driver from the HP 8210 driver. I changed the driver to HP Universal Printing PCL 6. Since I made this change, I have not had a problem with any print jobs for over a week.
