hi i am looking for a parts manual for a hp officejet 5610 all in one printer the seria no is [edited]   Q7310A  please if sombody can help or refer me to a page where i can download one
regards
allan
3 REPLIES 3
Hi @AE2468_CSS
Welcome to the HP Support Community. I'd be happy to assist you.
You can check the parts of the printer in the user guide : User Guide
Have a great day!
hi jay
i went threw the user manual from front to back no parts layout or description
in  there for the internal parts of the printer.
regards
allan
We do not have a manual for the internal parts of the printer.
You may order the replacement parts on the HP Parts Store, use the HP Parts Surfer to find the part number and If you've already looked for it and couldn't find it on the HP Parts Store, you may want to get it locally at the online store such as Amazon or eBay, etc...as the part numbers are universal.
Alternatively, I suggest you talk to HP support, and discuss your options, follow the below steps to get started:
1) Click on this link - https://support.hp.com/us-en/contact-hp
2) Click on Sign-in or select the product using the below step:
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Click on "Show Options". Fill the web-form, to populate a case number and phone number for yourself!
Also, if you are having trouble navigating through the above options, it's most likely because the device is out of warranty, if yes? please send me a private message with the region you are contacting us from, here's how private messages work: Click here for details.
If you wish to thank me for my efforts, you could click on "Accept as solution" on my post as the solution should help others too.
