To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
I am trying to print a calendar template page from Microsoft word on my HP officejet 5740 series printer.  I had no problems printing prior to this.  What I see in print preview is not what prints.  It leaves off all the info I entered into the calendar page.  I am running windows 10.  I printed a template page in November and had no problems. I attempted to check for driver updates for the printer but couldn't find any.
1 REPLY 1
Hi @carriannie ,
If you're experiencing issues where the printout doesn't match what you see in the print preview, there are several steps you can take to troubleshoot and resolve the problem. Here's a step-by-step guide:
Check Print Preview:
  • Open your calendar template in Microsoft Word.
  • Go to "File" > "Print" to see the Print Preview.
  • Make sure that the information you entered into the calendar page is visible in the Print Preview.
Update Printer Drivers:
  • Visit the HP official website to check for the latest printer drivers for your HP Officejet 5740.
  • Download and install the updated drivers if available.
  • Restart your computer after installing the updated drivers.
Check Printer Settings:
  • Open the document in Microsoft Word.
  • Go to "File" > "Print."
  • Ensure that the correct printer (HP Officejet 5740) is selected.
  • Check the print settings to make sure they match your requirements.
Print Test Page:
  • Print a test page from your computer to check if the printer is working correctly.
  • This helps verify if the issue is specific to the document or a general problem with the printer.
Check for Word Updates:
  • Make sure Microsoft Word is up to date. Check for and install any available updates.
  • Updates may include bug fixes that could address printing issues.
Try a Different Program:
  • Open the calendar template in a different program (e.g., Notepad, WordPad) and try printing from there.
  • This helps determine if the issue is specific to Microsoft Word.
Check Page Layout:
  • Verify that the page layout settings in Microsoft Word match the size and orientation of the paper you are using.
Clear Print Queue:
  • Open the print queue on your computer and clear any pending print jobs.
  • Sometimes, a stuck print job can cause subsequent printouts to be incomplete.
Check for Paper Jams or Low Ink:
  • Ensure there are no paper jams in the printer.
  • Check the ink or toner levels to ensure they are sufficient for printing.
Print from Another Device:
  • If possible, try printing the document from another computer or device to see if the issue persists.
I hope this helps.
Take care and have a good day.-
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
A_Gayathri
HP Support Community Administrator.
