Windows 11 Support Center. -
- HP Community
- Printers
- Re: problem printing with officejet pro 8720
01-03-2019 01:38 PM
I am having trouble trying to print, the printer software is installed on my pc but it wont let me print anything, when i do it tries to send it as a fax instead of printing, but i never setup the fax part of the install so i dont know why it is trying to do this, i can print with no problems straight from my mobile though? can anyone help?
cheers
Solved! Go to Solution.
01-03-2019 05:52 PM
Check Settings > Devices > Printers and scanners and make sure the 8720 is set as the default.
Please mark the post that solves your issue as "Accept as Solution".
I am a volunteer and do not work for HP.
01-03-2019 05:52 PM
03-20-2019 03:54 AM
It is already set as the default; and the Troubleshooter cannot find any problem; and it works with all other packages (e.g. MSWord; but this message comes up whenever I click on an attachment in Firefox and ask it to print
Francis
03-20-2019 12:07 PM - edited 03-20-2019 12:08 PM
@ Francisgardom, have you updated Firefox?
Have you tried another browser?
Can you print to a PDF file?
03-20-2019 12:17 PM
Thank you for your answer, Deen
Yes i have updated firefox
I am awaiting a reply from Hewlett Packard.
I haven't tried another Browser but I will do so
I have tried to print from Firefox Browser generated PDF files but it only works by printing them to PaperPort, Copying the text and pasting them into MS Word
Francis
03-20-2019 12:32 PM
@Francisgardom, what operating system are you using?
