To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
Hello everyone,
For some time I have not been able to print because I have the following message: Problem with the feeding system, where it asks me to try to replace the cartridges indicated with different non-empty cartridges. (the yellow one) I tried to replace them to no avail. nothing to do ! and I get the message to contact HP support if the problem persists.
My printer: HP OFFICE JET PRO 8719.
Maybe you can help me please and give me directions!
Thank you for your comeback.
Sincerely.
in french:
Problème au niveau du système d'alimentation
Y
Un problème existe avec le système de consommables.
Essayez de remplacer les cartouches indiquées par des cartouches différentes, non vides. Si le problème persiste, contactez l'assistance.
1 REPLY 1
@KhalidBou, Welcome to HP Support Community.
It sounds like you're dealing with a "Problem with the feeding system" error on your HP OfficeJet Pro 8719, which is typically related to issues with the paper feed or the cartridges. Here are a few troubleshooting steps that might help resolve the issue:
Check the Cartridges:
  • Make sure the cartridges are installed correctly and are not damaged. Even if you've replaced the yellow cartridge, sometimes a slightly misaligned or improperly installed cartridge can trigger the error.
  • Try removing the cartridges and reinstalling them to ensure they are seated properly.
  • If the cartridge is genuinely empty or faulty, replacing it with a new one from a trusted supplier could help.
Clean the Cartridge Contacts:
  • Turn off the printer and unplug it.
  • Remove the cartridges and gently clean the metal contacts on both the cartridge and the printer with a soft, lint-free cloth. This can help remove any dirt or debris causing a poor connection.
Check for Paper Jams:
  • Look for any paper jams, debris, or dust that might be blocking the paper feed area. Sometimes a tiny piece of paper can be enough to prevent proper feeding and trigger errors.
  • Open the rear paper access and check for any stuck paper or debris.
Reset the Printer:
  • Perform a hard reset by turning off the printer, unplugging it for 30 seconds, and then plugging it back in. After the reset, turn it on and check if the error persists.
Update Printer Firmware:
  • If possible, ensure that the printer's firmware is up to date. You can do this via the printer’s control panel or through the HP Smart app on your computer.
Try Another Set of Cartridges:
  • If you have an extra set of cartridges or can borrow a known working set, you might want to try them to rule out a defective cartridge as the cause.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
