Windows 11 Support Center. -
- HP Community
- Printers
- problem with the printer or ink system
08-06-2022 12:06 PM - edited 08-06-2022 01:24 PM
I have an HP Officejet Pro 8600 Plus printer. After replacing an ink cartridge with a genuine one, I tried to print a document and got the message "Printer Failure. There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP''. I turned the printer off and on, but the problem persists. I used the HP Print and Scan Doctor Utility to find out the ink levels. Under the black cartridge, there is the message ''shaidFailure''. Under Status, the other cartridges read either ok or low. If I replace the black cartridge, will the problem be solved? I installed it six days ago.
08-27-2022 01:14 PM - edited 08-27-2022 01:14 PM
Hi @techtamer,
Welcome to the HP Support Community
I understand you are getting an error message Printer Failure on your HP Printer. Not to worry I will help you to get a resolution to resolve the issue.
To assist better:
- Could you please share the screenshot of the error?
- Was there any recent update on the printer prior to the issue?
- Was there any paper jam or carriage jam issue on the printer recently?
While you respond to that, Let's perform a power drain:
- With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
- Remove USB cable, if present.
- Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
- Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
- Turn on the printer and wait till warm-up period finishes and the printer is idle
Update the printer firmware
- Click here to download and install the latest printer firmware from your product
- Click here to know different methods of updating printer firmware.
If the issue persists, then please follow the steps mentioned in this document: HP OfficeJet Printers - 'Printer Failure' Error
If the issue still persists, I'm sending out a private message to assist you with the next course of action.
Please check your Private message icon on the upper right corner of your HP Community profile Next, to your profile Name, you should see a little blue envelope, please click on it or simply click on this link.
ANAND_ANDY
I am an HP Employee
