HP Officejet Pro 8610 e-All-in-One Printer
I have an error message that there is a problem with the printer  or ink system.I have tried the recommended steps, but they did not help.
1 REPLY 1
Hi @Anna2484,
Welcome to The HP Support Community.
I understand the "Problem with Printer or Ink System" error on the HP Officejet Pro 8610 typically indicates a hardware or cartridge issue.
Here are some additional troubleshooting steps you can try to resolve the problem:
1. Power Reset the Printer
  • Turn on the printer.
  • With the printer on, disconnect the power cord from the printer and unplug it from the wall outlet.
  • Wait 60 seconds.
  • Reconnect the power cord to the printer and plug it back into the wall outlet.
  • Turn on the printer and check if the error persists.
2. Check the Ink Cartridges and Printhead
  • Open the ink cartridge access door and remove the cartridges.
  • Inspect each cartridge for damage and ensure they are properly vented (remove any protective tape).
  • Reinstall the cartridges, making sure they click into place.
  • Remove the printhead (if it's removable) and gently clean the electrical contacts on the printhead and inside the printer using a lint-free cloth slightly dampened with distilled water. Allow everything to dry before reinstalling.
3. Update the Printer Firmware Update the firmware on an HP printer
  • Make sure your printer's firmware is up to date, as outdated firmware can cause various issues.
  • Go to the HP support website and enter your printer model to find firmware updates.
4. Clean the Printhead
  • Access the printer's control panel, and navigate to Settings > Tools > Clean Printhead. This utility cleans the printhead to resolve common ink system errors.
5. Perform a Factory Reset
  • If the error persists, consider resetting the printer to its factory settings. Note that this will erase any customized settings on your printer.
  • To perform a reset: Turn on the printer, press the Back button (the button that looks like an arrow going left) 4 times, which should bring up a support menu. Navigate to the "Reset Menu" and choose "Semi-Full Reset."
6. Test with Different Cartridges
  • If you have another set of ink cartridges available, try using them to see if the error clears. Sometimes, the issue might be with the cartridges themselves.
Refer to this document:  HP Officejet Pro 8610 e-All-in-One Printer series User manual
HP OfficeJet Printers - 'Printer Failure' Error   There is a problem with the printer or ink system....
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution.
A_Gayathri
HP Support Community Administrator.
