HP OfficeJet Pro 9025 All-in-One Printer
Microsoft Windows 10 (32-bit)
where can i get a replacement paper tray? A piece broke off my paper tray 2 and I cant print without both trays installed
1 REPLY 1
 Hi @PattieT,
I'd be happy to help you!
I understand that this is a Hardware issue. Since the unit might need repair, I would request you to contact HP Phone support who can schedule a repair as per the warranty and the issue can be fixed.
For that to happen, we will give you additional instructions/information via Private Message.
Please check your inbox on the forums page for the private message.
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-
HP Community Moderator
