To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
deskjet 4720
i am having issue while photocopying the sizes of print comes out too be too small i tried resetting to defaults but same problem persists can anyone help me with this
1 REPLY 1
@mokshmdg
Reload the paper so that the printer detects the size, and then make sure copy job settings are correct.
Step 1: Reload the paper
Remove and reload the paper being used for the copy job. Make sure to slide in the paper width guides until they gently rest against the edges of the stack.
NOTE:
If a message displays on the printer to confirm the paper type and size, touch OK if the size is correct, or touch Change or Modify to change it.
If the issue persists, continue to the next step.
Step 2: Change paper and copy size settings
Adjust the paper and copy settings from the printer control panel menu to enlarge or reduce the size of copies.
NOTE:
For printers without a control panel menu, most models use default normal copy settings that cannot be changed. As a workaround, scan the original into the computer, and then use the editing tools in the HP scanning software to resolve any size issues. You can then print multiple copies of the edited scan file.
  1. Touch Copy, Copy Document, or Copy Photo on the printer control panel.
  2. Touch Settings or the gear icon  to access and change the following settings.
    • Resize or Size: Change the size of the copy. Options can include a list of presets, custom sizes between 25 and 400 percent of the original size, Fit to Page, and an Actual Size setting to make a borderless copy.
    • Paper Size: Select the plain or photo paper size for your copies, or select Automatic to let the printer detect the paper loaded in the tray.
    • Paper Type: Select the type of plain or photo paper for your copies.
    • Tray Selection: Select the paper input tray with the paper being used for your copies.
  3. Select Save Current Settings or Set as New Defaults to retain the settings for future copy jobs.
  4. Depending on the printer, touch Start, or return to the main Copy screen by touching Back, and then touch Start Black, Start Color, or OK to start the copy job.
Also, which phone do you have? If you're using the HP Smart App on it, please uninstall and reinstall and try again.
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thanks!
Have a great day!
I am an HP Employee
