To resolve issues with error EBS00P0013 on HP Smart App: Click here to view.
hi there i have a hp tango and have been with instant ink a good while but will be cancelling since i need to use it more and more the quality of the ink is just bad, it smears off all forms of paper from plain paper to photopaper glossy and matt
even just printing writing on normal paper using low quality settings to use less ink to normal settings the writing just smears all over the place
tried even HP papers
pretty sure instant inks are lower and worse quality than the ones you buy full price as this never happened before when i was using shop inks.
3 REPLIES 3
Hi @marklola82,
I'd be happy to help you!
To be able to answer you effectively, we need some information.
May I have the exact product name and number? Refer to this document for steps to find the product details. Do not share any of your personal information such as serial, phone number, email ID, etc.
  • Meanwhile, Follow the steps to fix streaked or faded prints. prints with incorrect colors, or other print quality problems.
  • Perform the following tasks in the order given. Use the printer after each task to see if the issue is resolved.
  • Low ink levels can cause print quality issues. If any cartridges are very low or empty, replace them with new Instant Ink cartridges.
  • Load plain white paper and run the cleaning tool.
  • Printers with a touchscreen or menus: On the printer, open the Settings or Setup menu, touch Tools or Printer Maintenance, and then touch Clean Printhead or Clean Cartridges.
  • Printers without a touchscreen or menus: Go to 123.hp.com or your app store to install the HP Smart app. Click the picture of your printer on the home screen to open Printer management options that include the cleaning tool.
  • If the page that prints has defects, the printhead might be badly clogged. Run up to two more cleaning cycles.
  • NOTE:
  • The cleaning page does not count against your pages printed for the month.
  • If you see blurry edges or jagged lines in your prints, try aligning the printhead.
  • Printers with a touchscreen or menus: On the printer, open the Settings or Setup menu, touch Tools or Printer Maintenance, and then touch Align Printer.
  • Printers without a touchscreen or menus: Go to 123.hp.com or your app store to install the HP Smart app. Click the picture of your printer on the home screen to open Printer management options. Select the option to align the printer.
  • If you did not replace your cartridges before, replace them now with new Instant Ink cartridges.
  • If you do not have new Instant Ink cartridges on hand, or if replacing cartridges did not help, contact HP Instant Ink support for assistance.
Home / Home Office: HP Instant Ink support
Business: HP Instant Ink for Business support
You may also refer to this document for further assistance.
Hope this helps! Keep me posted for further assistance.
Nal_NR-Moderator
I am an HP Employee
All the above is fine, it has absolutely nothing to do with any of that. Or the paper i use
It is the quality of ink in the instant ink cartridges...it is clear its a lower quality
Hi @marklola82,
What is the current OS installed?
Have you updated the firmware?
I would also need to know a few details regarding your Instant Ink account to help you get the ink cartridges sorted.
Since the instant ink account details are confidential, please send me the required information via private message.
I am sending you a private message with the information required. Please check the mailbox icon at the top-right corner of this screen.
Please check your Private message icon on the upper right corner of your HP Forums profile,
Next, to your profile Name, you should see a little blue envelope, please click on it.
I hope this helps resolve this issue completely,
Click the “Yes" on the bottom right to say “Thanks” for helping
Nal_NR-Moderator
I am an HP Employee
