Windows 11 Support Center. -
- HP Community
- Printers
- Re: Blinking power light after printer sits idle for a while...
10-01-2019 12:50 PM
Hi all, I have a HP Officejet Pro 8600 Plus. I've run into an issue where if the printer is sitting idle for too long, the power button goes to flashing on and off slowly. At that point I can't send a job to print on this printer.
To get it to work, I have to unplug the printer, and plug it back in. It then works again, until I let the printer sit idle too long. Then it goes back to a flashing power button.
Any ideas or help to fix this?
Thank you!
10-04-2019 03:31 AM
Hi @C_Beau
Disable the Sleep Mode if it is enabled from the printer's control panel -
1) Touch Help.
2) Touch Discover.
3) Touch Eco Tips > Save Energy > Sleep.
If the issue still persists, try these steps to reset the printer -
1) Take out the cartridges.
2) Unplug the power cord from the printer & wall.
3) Wait for 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not to a surge protector.
5) Insert the cartridges back into the printer.
Also, try updating the printer's firmware - HP Printers - Updating or Upgrading Printer Firmware
Have a great day!
Asmita
I am an HP Employee
