×InformationWindows update impacting certain printer icons and names. Microsoft is working on a solution.
Click here to learn moreInformationNeed Windows 11 help?Check documents on compatibility, FAQs, upgrade information and available fixes.
- HP Community
- Printers
- Re: Color LaserJet Pro M255dw - Supply Problem
03-30-2021 08:43 PM - edited 03-30-2021 08:50 PM
i got Color LaserJet Pro M255dw with message Supply Problem. is there a way to reset the toner levels? I'm asking because i got the printer replaced under warranty and i had the toner already in very low state. still fine for printing, and they did not supply replacement toner.
Solved! Go to Solution.
03-31-2021 11:35 AM
You only need to replace the cartridge that is showing you an error.
03-30-2021 11:57 PM
No. When you install old used toner cartridges with a low level ( I think under 15% ) the replacement printer will report old used cartridges with a supply problem message, but the printer will continue to work, you only will not have an estimated toner level.
03-31-2021 10:05 AM - edited 03-31-2021 10:11 AM
Ok. the new printer is showing the error 10 on yellow cartridge. if i replace it, and leave the others in, will the printer resume printing? The other cartridges show used status.
03-31-2021 07:27 PM
Didn't find what you were looking for? Ask the community
