Color LaserJet Pro M255dw
i got Color LaserJet Pro M255dw with message Supply Problem. is there a way to reset the toner levels? I'm asking because i got the printer replaced under warranty and i had the toner already in very low state. still fine for printing, and they did not supply replacement toner.
You only need to replace the cartridge that is showing you an error.
My profile on LinkedIn
7 REPLIES 7
No. When you install old used toner cartridges with a low level ( I think under 15% ) the replacement printer will report old used cartridges with a supply problem message, but the printer will continue to work, you only will not have an estimated toner level.
This doesn't help as the printer refuses to print. i require a way to reset the chips on the toner to usable level so printer will start printing
There is no option to reset, if the printer will not print you will probably need new cartridge(s).
Ok. the new printer is showing the error 10 on yellow cartridge. if i replace it, and leave the others in, will the printer resume printing? The other cartridges show used status.
Finally an answer I can work with. I was over 3 hours on chat and call with level 1 and level 2 support. They just read scripts, and don't care about the user experience or even questions. Thanks Valsimot 🙂 I will post here with results when I replace the toner. Right now the replacement genuine toner is being shipped from a 3rd party vendor.
Thanks. Yellow cartridge replaced. Printer resumed printing.
