To resolve issues with error EBS00P0013 on HP Smart App: Click here to view.
Something wrong in configuration page printed out my printer ?
It's visible now, and it looks that you have bad colour ink cartridge that needs to be replaced.
Black prints acceptable, but your colour prints only in those magenta tones. When you replace the colour ink cartridge the print will be fine.
My profile on LinkedIn
As you told me, I changed my color ink cartridge and this what my printer gets out:
PhotoScan.jpgI see that now the colors are ok, but if I try to print it tells me that there is a problem with code 0x800705B4. What kind of problem is ?
Any idea about the problem ?
The colours are now much better, don't know much about error code but Google says it's something Windows 10 updates related
Problem solved !!! Thank you so much for your support and for your patience...
regards
