Windows 11 Support Center. -
- HP Community
- Printers
- Re: HP Deskjet 3635 Blinking lights problem
11-14-2018 09:02 AM
Hello to all,
My HP Deskjet 3635 printer has been on an error state unable to perform any activities. Specifically, the power button is blinking fast, while the wireless light is blinking slower and the wireless icon is on.
Earlier, the power button was blinking fast, while the Wifi-Direct light was on. I tried to perform all kinds of resets I found online and the after I holded the power button and hit two (2) times the white/black copy and three (3) times the cancel button it switched to the state I mentioned above.
Any suggestions except for buying a new one? 🙂
Thank you all in advance
11-15-2018 01:09 PM
Welcome to HP Support Forums. A really great platform for posting all your questions and finding solutions.
I have gone through your Post and I would like to help
Let's start with a printer reset
(1) Turn the printer on, if it is not already on.
(2) Wait until the printer is idle and silent before you continue.
(3) With the printer turned on, disconnect the power cord from the rear of the printer.
(4) Unplug the power cord from the wall outlet.
(5) Wait at least 60 seconds.
(6) Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
(7) Reconnect the power cord to the rear of the printer.
(8) Turn on the printer, if it does not automatically turn on.
The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
Wait until the warm-up period finishes and your printer is idle and silent before you proceed
You can also download the Firmware from this Link: https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-ink-advantage-3630-all-in-one-printer-se... if you have a USB cable
Keep me posted how it goes
Thank you and have a great weekend 😊
If the information I've provided was helpful, give us some reinforcement by clicking the "Solution Accepted" on this Post and it will also help other community members with similar issue.
KrazyToad
I Am An HP Employee
