Windows 11 Support Center. -
- HP Community
- Printers
- Re: HP Envy 6032 won't print unless I power off and on again
09-03-2022 09:20 AM - last edited on 09-03-2022 09:25 AM by MarcusC
I have an HP Envy 6032.
Every time I want to print, it errors out.
The only way I can get into print is to plug out the power source and back in again.
Nothing happens when I press the power button; it does not turn off when it's on.
Please watch this video where I show exactly what happens !
Please advise. This is frustrating.
Thank you in advance for any help.
Solved! Go to Solution.
09-09-2022 07:49 AM
@StewHP
Welcome to the HP support community.
I understand that your printer is not responding while printing, I am glad to assist you.
Use HP Print and Scan Doctor to fix connectivity and printing issues.
Download HP Print and Scan Doctor.
- Run HPPSdr.exe from the download location on your computer.
- Once HP Print and Scan Doctor opens, click Start, and then select your printer.
- If your printer is not in the list, turn it off and on, and then click Retry.
- If there is a connection problem, follow the instructions in HP Print and Scan Doctor.
- If a screen prompts you to turn on printer updates, click Yes.
- If a screen prompts you to make your printer the default printer, click Yes.
- Try to print.
.Assign a manual IP address to manually connect the printer.
Find the printer IP address to assign it manually.
- On the back of the printer, press and hold the Wireless button for at least three seconds.
Setting a Static IP Address
Once you know your printer’s IP address from the page you printed, entering it is pretty easy. Here’s what you do:
- Run your Web browser.
- In the Web browser’s address bar, type the IP address of your printer and press Enter. Assuming you entered the right address, the HP printer control panel should appear.
- Click the Networking tab.
- Under Connections, click Wireless.
- Under IP Address Configuration, click Manual IP.
- Enter the IP address, subnet mask, and default gateway in the appropriate boxes.
- Click Apply.
Refer to this HP document for further assistance:- Click here
Let me know how it goes.
If this helps, please mark the public post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
09-09-2022 07:49 AM
@StewHP
- Try to print.
- Click Apply.
Cheers.
Sandytechy20
I am an HP Employee
