To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP Ink Tank Wireless 415
Microsoft Windows 10 (32-bit)
Hi Everyone,
My HP Ink Tank Wireless 415 stopped printing couple of days ago. There's no error message whatsoever, the ink status is good and there are papers. I restarted both the computer and printer, and reset the latter (unplugging/plugging while on, twice), but it didn't work. I also tried different documents without success.
Then I used HP Print & Scan Doctor, which reported that it installed some updates and fixed some "port" issue, and asked for restart. Then neither the print-test  nor the local document print worked!
The wired thing is that every time I am giving a print order the printer reacts by receiving the order and even make some noises as if it is printing, but then nothing happens and the order disappears from the printing list as if it was done.
Appreciate your help.
Thanks
Mouyad
@Mouyad, Welcome to the HP Support Community!
I understand you are not able to print from your computer. I appreciate your efforts in trying to resolve this issue by performing the necessary troubleshooting steps.
As you are able to make copies, it means the printer hardware is working fine and this could be a driver issue.
Use the HP Smart app to print and scan from your Win 10 PC
Click here to download and know more about the app.
If the issue persists, install the printer using the TCP/IP port:
  1. On the PC, go to Control panel > Devices and printers > Remove the existing printer entry > click on Add a printer(at the top)
  2. Under 'Choose a device or printer', click on 'The printer I want isn't listed'.
  3. Select 'Add a printer using a TCP/IP address'
  4. Find the IP address of the printer by tapping on the wireless/ethernet icon on the printer screen
  5. Type in the 'IP address in Hostname or IP address' box, click next
  6. Proceed to the next steps by following the on-screen instructions.
  7. Try printing.
Have a great day!
KUMAR0307
I am an HP Employee
1 REPLY 1
  7. Try printing.
Have a great day!
KUMAR0307
I am an HP Employee
