FYI It's now been several days and still not a single error, so I'm declaring the factory reset a success!
Did the same thing you suggested , and it worked for me too! You're absolutely my hero, I was about to decommission the printer, then I've tried your solution and it seems that everything is working again. Don't know the reason for that behavior, seems like a firmware issue but I didn't update nor I've touched the configuration for a long time so I don't actually know. But in the end it doesn't matter, the issue is solved.. so far so good...seems you saved my printer 🙂
