Windows 11 Support Center. -
- HP Community
- Printers
- Re: HP OfficeJet Pro 8715 Printer Error There is a problem w...
08-16-2021 02:01 PM
Did the same thing you suggested , and it worked for me too! You're absolutely my hero, I was about to decommission the printer, then I've tried your solution and it seems that everything is working again. Don't know the reason for that behavior, seems like a firmware issue but I didn't update nor I've touched the configuration for a long time so I don't actually know. But in the end it doesn't matter, the issue is solved.. so far so good...seems you saved my printer 🙂
- « Previous
- 1
- 2
- Next »
Ask the community
