I bought an HP Officejet 8600 Plus and am trying to connect to my wireless network.
I have the printer connected directly to the computer.
I have restarted the computer, printer and time capsule.
I am running OSX 10.8.4 on my imac.
My wireless router is a time capsule that is current with all firmware.
When I try to connect the printer to the wireless network it tells me that "More than one access point/wireless router has been found that matches your wireless network name (SSID)".  None of the other 6 devices that are using the wireless connection see this second SSID with the same name and I cannot find in Airport Utility where a second network exists.
Any ideas?
Have you gone into the router settings? It sounds like it is set to dual-band and is sending out two signals. If you go into your settings and change it only broadcast at 2.4GHz, that should help you connection issues.
-------------How do I give Kudos? | How do I mark a post as Solved? --------------------------------------------------------
Signature
5 REPLIES 5
Signature
It looks like that was the problem.  It was set up to use 802.11n and 802.11g.  Curious why none of my other devices have an issue with this - but my HP printer does.
Thanks very much for the help.
No problem. Sometimes these printers are picky with the WiFi connections, I honestly couldn't tell you why though. I'm glad everything is back up and running!
Signature
After a couple of hours trying HP's possible solutions.  I solved the problem, by unplugging a wireless range extender.
I too have this problem but have no idea how to correct...I've tried disconnecting and restarting routere, printer and computer...no luck!!
