Windows 11 Support Center. -
- HP Community
- Printers
- HP4655 will not print over wireless
06-18-2018 06:29 PM
Bob, I downloaded the firmware and it says it is already up to date so I guess my latest re-installation of HP4655 must have included the firmware update.
I think since this problem appears to be specific to Adobe Acrobat Reader DC, I will uninstall and re-install it. Couldn't hurt.
I just read the notation of giving a "thumbs up" if I find the answer helpful. I did not notice before so this is my first "thumbs up". You deserve many kudos and thumbs up. Thank you.
06-18-2018 07:38 PM
Bob, uninstalling and re-installing Adobe Acrobat Reader DC WORKS.
Thanks for all your help and efforts.
I uninstalled and re-installed once before and it didn't work.
I don't care why it didn't work before. It's working now. 🙂
Have a wonderful evening. You are fantastic.
Mary
06-18-2018 07:59 PM
I downloaded the Officejet 4655 driver and installed it an printed from Reader DC without any issues using my Officejet Pro 8600 with the 4655 driver.
I am about out of ideas, but I do wonder about a couple things: please go to control panel. devices and printers. Right click on the Officejet 4650 series printer and select Printer Properties, Ports. Is the checked port a WSD port? I have seen some cases where a WSD port is problematic, changing to a standard TCP/IP port and assigning a static IP address has solved some issues.
Have you always been using the same PDF file for testing? If so I would suggest trying a different one - just to make sure the file is not the issue.
I am not an employee of HP, I am a volunteer posting here on my own time.
If your problem is solved please click the "Accept as Solution" button
If my answer was helpful please click "Yes" to the "Was this post helpful" question.
06-18-2018 08:20 PM - edited 06-18-2018 08:20 PM
I had started my last response before your post, I did not see that your issue was resolved until after it posted.
I am glad things are working, that was a strange one - you expect installed programs to just work :-). I did send you a private message, click here to get to the private message system: https://h30434.www3.hp.com/t5/notes/privatenotespage
- « Previous
- 1
- 2
- Next »
