Windows 11 Support Center. -
- HP Community
- Printers
- Re: HP8720 door open error-Where is door sensor activator
06-22-2018 09:31 PM
My 8720 cover is closed. Yet I get an error stating the door is open. I have tried the unplug, plug back in resets. Still have error. I tried looking for a door sensor activator but can't find it. Any ideas? Does anyone know where it may be so I can see if it needs replacing? Could it be another reason I can't get rid of error?
06-23-2018 05:12 PM
Thanks for engaging in HP support Forums! This is a wonderful location to converse with the community, get assistance and find tips!
As I understand you have the error - "the door is open",
Splendid effort and fabulous description of the issue before posting. Kudos to you on that score. You are a valued HP customer and it is paramount to assist you here. I take it as a privilege to share this platform with you.
No worries, as I'll be glad to help you, that said, I'll need a few more details to dissect your concern & provide an accurate solution:
Did you close the cartridge door completely?
Have you checked the cartridge door for obstructions?
Did you reset the printer?
As I see that you have contacted our HP Twitter support and they have helped to diagnose the issue, Before you contact our HP phone support, I would like to ensure you have followed these steps here:
Step one: Close the cartridge door completely
If the cartridge door is not completely closed, the error message displays.
Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
Figure : Examples of closing the cartridge door (your product might vary)
NOTE:
To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
Check the product control panel to see if the error message still displays.
If these steps resolved the issue, there is no need to continue troubleshooting.
If the issue persists, see the next step.
Step two: Check the cartridge door for obstructions
Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE:
Bits of paper, packing materials, and tape might prevent the door from closing completely.
Remove any obstructions.
Step three: Reset the product
Press the Power button (
) to turn on the product.
Disconnect the USB cable from the back of the product.
CLICK HERE FOR MORE STEPS AND INSTRUCTIONS.
(By the end of this article all the issues should be resolved)
If you have followed the steps suggested and still having the issue. I would recommend you contact our HP phone support to have it repaired or replaced.
HP Support can be reached by clicking on the following link:
- Click on this link – www.hp.com/contacthp/
- 2) Click on “Continue as guest”.
- 3) Enter the serial of your device.
- 4) Select the country from the drop-down.
- 5) Click on “Show Options”.
Fill the web-form. A case number and phone number will now populate for you.
Hope this helps, for any further queries reply to the post and feel free to join us again
Feel free to post your query for any other assistance as well,
It's been a pleasure interacting with you and I hope you have a good day ahead.
If you wish to show appreciation for my efforts, mark my post as Accepted Solution.
And click on the Purple Thumbs up icon at the bottom of my comment.
Regards,
Jeet_Singh
I am an HP Employee
