Windows 11 Support Center. -
- HP Community
- Printers
- Re: How can I fix printhead problem on my printer
02-26-2025 09:11 AM
Hi @Yacov1,
It sounds like you've encountered an issue with HP printers, specifically the Officejet Pro 6970, which is the printhead error. Please try the basic steps on the device first and let us know how it goes.
Please remove the Cartridges from the Printer if possible and try Hard Reset do keep us posted to help you better
** Hard reset :
1. Turn the printer On, if it is not already on.
3. With the printer turned on, disconnect the power cord from the rear of the printer.
4. Unplug the power cord from the wall outlet.
5. Wait at least 60 seconds.
6. Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
7. Reconnect the power cord to the rear of the printer.
8. Turn on the printer, if it does not automatically turn on. The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Please uninstall the HP Smart app --> restart the Device, Wi-Fi router and printer --> install it back and check
Please update the Firmware from the link this will help on how to update the firmware on the printer or devices
I hope this helps.
VikramTheGreat
HP Support
02-28-2025 09:39 AM
Hi @Yacov1,
I hope this message finds you well. I wanted to follow up on the technical issue that we discussed earlier and confirm that it has been successfully resolved.
If you encounter any further issues or have any additional questions, please do not hesitate to reach out to us. We are here to assist you and provide any necessary support.
I will be archiving this case for now, however, you can respond to the same thread to continue the conversation.
Take care and have a great day ahead!
VikramTheGreat
HP Support
