cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
2 1 0 0
Message 1 of 3
80
Flag Post
Instant Ink Connection Problems
Officejet 8720
Following router replacement on a small network, a customer reported 3 weeks after installation that the printer was not connecting to the Instant Ink service.   This had previously worked fine.
The printer was printing from the email service okay and the internet connection seemed okay
Online searches revealed possibilities including printer date time, DNS settings on the printer and perhaps a need for firewall ports to be configured.  None of these appeared to be the issue, since they were unchanged from the previous working configuration.
Following further diagnostics and network packet capture, I found the the printer connections to the Instant Ink service were not reaching the WAN since the packets were set not to fragment, and were being rejected by the router.
Once this was discovered, I determined the highest MTU value that allowed connection to Instant Ink, tweaked the MTU value in the router to match and Instant Ink service connections were restored (i.e. reduced the MTU value slightly from the specified value).  No firewall rules needed.
This seems to be a solution that I've not found documented online.
I accept that this was probably a misconfiguration of the router MTU, but I suspect that many people installing a new router would not change the default value.
Has anyone else discovered an issue with fragmented packets preventing connection to Instant Ink?
2 REPLIES 2
Highlighted
Level 17
Level 17
29,346 29,068 5,038 11,481
Message 2 of 3
Flag Post
Hi,
Have you tried restoring the network defaults for the printer and then reconfigure it? to deny any remaining settings from your old router.
Swipe down the top gray bar and then click the Setup icon.
Select Printer Maintenance.
Under Restore Settings select Network and confirm any prompt, then reconnect the printer if it is wirelessly connected
If there is no change, is the printer connected to the network wirelessly or with an ethernet cable?
Shlomi
Say thanks by clicking the Kudos thumb up in the post.
If my post resolve your problem please mark it as an Accepted Solution 🙂
Reply
0 Kudos
Highlighted
Author
New member
2 1 0 0
Message 3 of 3
Flag Post
@Shlomi
The printer is connected to a wireless network,  I first tried another wireless network from a mobile hotspot and since that connected okay, it showed that it was some issue with the local network and not the printer.
I am convinced that the problem was packet fragmentation but just surprised that I've not seen that mentioned anywhere.
thanks
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
