I am using a Mac OS X 10.6.8
I had hoped to connect them wirelessly but it wasn't the priority.  What I need was a dependable printer.  I've tried several times to get it to print in color and it only seems to work when I run a test page from the printer itself.  The diagnostics page is 100% correct.
Not sure what to do...
V
Is the grayscale option selected in the printer driver?
Say "Thanks" by clicking the Kudos (Thumbs up) button in the post that helped you.
Please mark the post that solves your problem as "Accepted Solution"
8 REPLIES 8
Happy that my suggestion was able to help you to resolve the issue. Thanks for the kudos and marking the issue as resolved.
I checked everything I could, including the print driver settings.  Everything is set for color printing.  However, it's still not printing color.  I installed the Basic driver package.  It should still print in color, shouldn't it?
I can't get the printer to print in color. I put in the ink that came with the printer. I just installed it 30 minutes ago. Help!!!
where do I find the greyscale?
Did you get an answer to this?
Where is the grayscale option? I can't find this.
I can't print in color  HP8710,  Mac
I have no idea how to adjust the "grayscale"? / color?
