- HP Community
- Printers
- Re: PageWide Pro - Will not Print More than One Copy
03-24-2017 04:42 AM
I have the HP PageWide Pro 477dw MFP, a good printer but will not print more than one copy.
For Example, open a word doc, select print, number of copies 5 result only 1 copy prints and the print job ends.
Please help
Solved! Go to Solution.
03-24-2017 04:59 AM
I don't know if this is relevant or not, but see this old thread https://h30434.www3.hp.com/t5/Inkjet-Printing/printing-multiple-copies/m-p/4903265 regarding a similar problem wih a LaserJet 1320.
The resolution was to disable Mopier mode in the printer driver properties.
03-24-2017 04:59 AM
