cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
3 2 0 0
Message 1 of 4
88
Flag Post
Print Error-Problem with printer or ink system
Office jet 6600
There is a problem with the printer or ink system.
3 REPLIES 3
Highlighted
HP Support Agent
HP Support Agent
31,101 31,050 2,569 3,876
Message 2 of 4
Flag Post
@Ljwooding1-_ Here's a few steps that should help resolve the issue:
Step 1: Verify the cartridge numbers
Make sure the cartridge numbers match your printer and where the country/region the printer was purchased.
Go to HP Store and verify the cartridge numbers for your printer model and country/region. Replace any incompatible cartridges.
Step 2: Reset the printer
Reset the printer to recover from printer failures.
  1. With the printer turned on, disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
    NOTE:
    HP recommends plugging the printer directly into a wall outlet.
FOR DETAILS & FURTHER INSTRUCTIONS, USE THIS LINK: CLICK HERE & SKIP TO STEP 3 ONWARD
(By the end of this article all the issues should be resolved)
P.S: Welcome to HP Community 😉
Let me know how that pans out,
If you feel I was helpful, simply click on Accept as Solution to help the community grow,
That said, I will have someone follow-up on this to ensure you've been helped,
Just in case you don't get back to us,
have a good day, ahead.
Riddle_Decipher
I am an HP Employee
Reply
0 Kudos
Highlighted
Author
New member
3 2 0 0
Message 3 of 4
Flag Post
Thank you to the community for your quick support. Unfortunately your responses were the same and it doesn’t work.
Reply
0 Kudos
Highlighted
HP Support Agent
HP Support Agent
Message 4 of 4
Flag Post
@Ljwooding1-_ These are tried and tested steps that have helped many, that said, if you've gone through the steps and the link, yet the issue persists, this could be a hardware malfunction and I suggest you talk to HP support and discuss your options, follow the below steps to get started:
1) Click on this link - http://www.hp.com/contacthp/
2) Click on Sign-in or select the product using the below step:
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Click on "Show Options".
Fill the web-form, to populate a case number and phone number for yourself!
Also, if you are having trouble navigating through the above options, it's most likely because the device is out of warranty, if yes? please send me a private message with the region you are contacting us from,
here's how private messages work: Click here for details.
If you wish to thank me for my efforts, you could click on "Accept as solution" on my post as the solution should help others too.
Riddle_Decipher
I am an HP Employee
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
